HumberJewel
I have the lower unit on the bench for water pump service. This engine has not been run for 5 years and stored outside.
I had read that you can test the hydro-electric shift by powering the solenoid(s) and hand turning the crank. It should take one revolution.
I grounded the case and applied +12VDC to the green solenoid lead and hand turned the driveshaft a couple of turns. It stayed in forward.
Same result with power to blue, and power to blue and green.
Both solenoids give resistance readings of 5.7 to 5.9 ohms.
When I apply power to the solenoid(s) I don't hear or feel any click or other noises.
What are the next steps to troubleshoot this?
