El Pescadorcan you pleasse recommend spark plugs
discobayken
"I just added the pertronix EI
"I just added the pertronix EI on my aq125a. Sould I use the factory plugs and gap them a bit wider...or are there other spark plugs you might recommend? Thank you!
btw, my idle went up a couple hundred rpms from just installing the EI unit."
"Ken, gapping your current spa
"Ken, gapping your current spark plugs a little wider (as stated in the Pertronix instructions) should improve performance.
Brands are a matter of personal preference. FWIW, I have been using for a few years NGK spark plugs with v-grooved center electrode with good results."
