Hello, I have a mercury 9.8 that I have been trying to get to stop overheating for a month now. Replaced water pump assembly twice, new water tube seals and grommet, new exhaust baffle plate and gaskets, powerhead and base gaskets. After all that finally tore motor down and found water had been getting into crankcase so I replaced lower bearing and piston rings and all seals as well as new reeds. Motor starts up and runs, but will take a little while to get water into the thermostat housing. Shortly after startup steam or smoke begins shooting from the tell tale or thermostat housing if I have cover off and the exhaust plate gets hot quick. I have hooked a hose directly to the water tube and it will run great and stay completely cool. If I put the lower unit in a bucket and spin the drive shaft with a drill I get water shooting from the water tube. Out of ideas, any help is appreciated.
