Dumb Question - Help
jdguns13
I have a 1993 Alpha 1 Gen 2 with a curious looking "V" notch on the leading edge of the lower outdrive. I will try to post a picture. With the lower oil plug installed and my finger over the vent I can actually blow air thru into it. No water in the oil when it was drained best I can remember. I only had this boat on the lake once (23' Pro line CuddyFish) with no issues. Do I need to plug this up with some epoxy?
It's a water psi speed line there should be a plugged line in engine compartment this is used to measure speed while driving if u have the psi sensor installed
Ayuh,... It's the pitot hole for the speedometer.......
in simpler terms, it is the speedometer pick up water inlet. There is actually a small piece of hard tubing inside of that notch if I am not mistaken.
