Ayuh,.... You'll be just Fine....
1.... Though I admit, I've been movin' to Merc Perfect-Seal...
2.... I've been slatherin' things I've taken apart with Never-Seize most all my life...
Especially if I thought I might wanta take it apart Again someday...
1.... I too like Perfect Seal.... pretty hard to beat it.
2..... Bill, for anything that is not subjected to sea water, sure..... it works well. I been using Never-Seez for over 45 years.
In fact, I have one can of Never-Seez that is probably older than many members here.
But give this a try on your salt water stern drive nuts/bolts..... you may be playing a different tune in the not so distant future.
Rick,
I have been using the silver never seize by permatex on the spark plug threads for longer than I can remember, should I quit doing this? I am a fresh water trailer sailor.
Thanks.
NO.... don't quit using it for this application..... works great!
Your spark plug threads are not going to be subject to salt water.
(See above response to Bill)
Permatex® Anti-Seize Lubricant
A highly refined blend of aluminum, copper and graphite lubricants. Use during assembly to prevent galling, corrosion and seizing and to assure easier disassembly. Temperature range: -60°F to 1600°F (-51°Cto 871°C). Salt, corrosion and moisture resistant –ideal for marine use. Non-aerosol version meets Mil Spec #907E. Aerosol - Level 3*
If you are reading this from a can of Never-Seez that contains aluminum and/or copper, I'm quite surprised.
It's these two elements that offer superior anti-seizing ability.
However, these same two elements will give you grief when salt water gets to it for any duration.
I love these products.... don't get me wrong.
I simply pick and choose them for the appropriate application!
Do this, and you'll be fine.
