I want to check the gear oil in my 91 DP-A to make sure there is no water in the oil. I want to remove the lower unit drain plug and let a small amount of oil drain into a bowl/pan. My question is...will I be able to get a a new oring in while gear oil is dripping out. I want the oring to seat correctly when i put the threaded plug back in. A V/P mech. changed out the gear oil in the beginning of the season last year and pressure tested it. I did not put enough hours on the drive last season to warrant a gear oil change. I heard if you have any water in the drive it will settle to the bottom..is this true.
