Does my outdrive have its own waterpump
crowley
i have a 1972 aq130c with a 25
i have a 1972 aq130c with a 250 outdrive and i know it has a water pump on the front of the engine but i am woundering if the outdrive will also have one in lower unit.
"None of the Volvo Penta AQ se
"None of the Volvo Penta AQ series drives had a sea water/raw water pump in the drive. All are engine mounted pumps.
This means that the entire suction side must be air tight.
Check and/or replace:
**Water neck fitting
**S hose and connections
**Lower pivot tube O-ring
**Connections at inside of transom shield
**Connection to the raw water pump
Keep the pump in good condition, and good impeller in the pump, all connections tight, and she'll work great for you."
thanks for your help i just bo
thanks for your help i just bought the boat and want to make sure all is well before i take it out
