I just bought a 89 Steiger Craft. It has a 350 freshwater cooled carburated engine with 36 hours on the new motor. It has a 290 single prop drive that just had bearings and u joints replaced. It ran out excellent when I test drove it. The hull is in excellent condition with its original gel coat shining and the boat is solid as a rock. I bought a Sea Sprite last year that I thought only needed a motor. After I bought a 2005 OSXI 5.7 engine I found the rotted transom. I was tempted to rebuild the Sea Sprite but I wised up before I killed myself and dumped a ton of money into the water. I saved the 290 dual prop drive and everything else I could take off of the Sea Sprite and junked it. Now I have a dual prop lower unit I can put on the new boat and I'm leaning to putting the fuel injected motor in. One part of me is saying just fix what needs to be done and enjoy it and the other part of me is saying put the new motor in. My problem is I can never leave good enough alone. I bought the 2005 motor from a Volvo dealer in Rode Island last spring. It was a motor that Volvo had him replace because it got water in the oil. He replace the motor under warranty and Volvo let him keep the engine. It has 52 hours on all the accessories(fuel pump,manifolds,heat exchanger,fuel injection and so on. He took a 1999 zz4 block he had and put all the parts into the replacement block with new rings,bearings and gaskets. It's such a nice package with the single serpentine belt,remote oil filter and all the accessories. I love the way fuel injected engines snap to life and the performance and fuel economy is great. Should I leave it alone or should I open the can of worms and change it out?
http://i1209.photobucket.com/albums/cc399/bicounty/CIMG4226.jpg
http://i1209.photobucket.com/albums/cc399/bicounty/Stieger Craft/CIMG4362.jpg
