RicardoMarine
Gold Medal Contributor
Bob, unless I'm not seeing something correctly, they do have a driven gear, but it is a separate gear not directly attached to the distributor shaft.......... Yes/No?
This would be the same driven gear that is swapped out for a RH rotation camshaft. The same two gears that cause the change to the thrust direction... yes/no?
