"I got my intake manifold re-i
"I got my intake manifold re-installed yesterday. I think the initial problem was the manifold bolts needed to be re-torqued. My guess is the gasket was just loose enough so coolant flowed past the coolant crossover and into the bolt holes.
The guy who did it before used the cork strips at each end but I followed the manual and used RTV.
I think I made a mistake with the distributor though. I marked the position of the distributor housing to the intake manifold and also marked the distrbutor cap to distributor orientation (hard to get that wrong though, you would have to be off 180 degrees).
What I didn't mark was the position of the rotor to the cap. The crankshaft hasn't moved.
Do I need to follow the "engine disturbed" procedure or is there a short cut I can use?
thanks,
Bob"
thanks,
Bob"
