duo_prop_dad
"I have a 290 DP that is going
"I have a 290 DP that is going to swapped with a 290SP. Then I 'm gong to swap lowers to be a DP again.....
The Dp uses gearlube typically and the Sp uses motor oil.
When I swap these drives out do I need to check anything internal or swap anything internal to maintain proper lubrication?
Ultimately, the SP will be a DP and use gear lube.
Thanks, John"
Thanks, John"
