DF140
"Thanks, but do you have the m
"Thanks, but do you have the measurements ? The motor is too heavy to use as a jig when making the holes."
"Hi there, SUZUKI 140 about &#
"Hi there, SUZUKI 140 about '87 model runs well but not peeing, where should it pee from and how long after starting should pee begin, have only run it with ears on and only for about a minute.
Any help would be appreciated, cheers."
"I have a 1986 dt suzuki 140 t
"I have a 1986 dt suzuki 140 that is down on power and have heard that it is better to di-connect the oil injection and use pre mix fuel, tried this and it seeemed to work but I am un sure of the pre-mix rate fuel I should be using andhow to disconnect the oil injection from the motor THANKS FOR ANY COMMENTS PAT"
