kerry_smith
"I have a 1954 Evinrude #25916
"I have a 1954 Evinrude #25916 that has a cylinder not getting fire (top). Points are set to spec. I attached a wheel puller where the inspection hole plate goes but the flywheel will not come off to determine if the issue is in the wire or in the magneto assembly, penetrating oil applied but to no avail, so far. I am affraid to put too much torque on the top of the crankshaft for fear of stripping the three attaching receivers for the cover bolts.
Ideas?"
Ideas?"
