My newer (2 years) Stb cutless bearing is bulging out in opposite corners and I can see the rubber rotate a hair when I rotate the shaft. The engine must have shifted at some point because it's closer to the edge of the shaft log.
My plan is to remove the strut, install a new bearing, center the shaft in the log, replace all four engine mounts and start from scratch. I have a brand new strut with a cutless bearing already installed. Can I press that one out and install it in the old strut? It's the opposite side or I would just install the whole strut.
Is it possible to remove one w/o doing damage or should I just leave that as is and get a new bearing? It's never seen water so corrosion won't be an issue.
Bob
Bob
