"Had an interesting drive home
"Had an interesting drive home yesterday 2- nautical miles on one motor, the other 454 Crusader has been running great, all of a sudden started spluttering and died- would restart but immediately die - through process of elimination traced the problem to be no spark from coil to Distributor, found if i figgled with the "on/off" switch (not ignition) on dash the engine would start but still die - cut the switch wires and joined but then would not start at all ??
Very confused - i thought a switch simply joined seperated two wires!!
Possible it may be something else -coil? will swap over today and try but any other ideas welcomed
thanks
CLinton"
thanks
CLinton"
