kookoojuice
I have a cooling problem, but may or may not be related - Any ideas would be great help.
Crusader 454, fresh water cooled, Raw water Risers
boat stopped pumping water out of starboard engine all of a sudden when I fired her up for the first time in 2 weeks. Boat until then has been running great
Replace the raw water pump with brand new one – new impeller also.
Unconnected the hose from seacock – check to get water there at seacock (YES)
Checked to see if at end of hose from seacock to water cooler – getting water (YES)
Checked to see after water cooler if getting water (YES)
Checked to see if after water cooler – hose to pump is getting water (yes)
Checked to see if pump is getting water (yes)
Checked to see if after pump, but before heat exchanger is getting water (Yes)
Checked to see if after heat exchanger is getting water to riser (Maybe – this is where things start to get a little hairy)
WE tested this and I was not getting water past the heat exchanger – however with a hose hooked out (tap water) I could get water through it.
When we opened the heat exchanger – no water in it really and it should have been full.
Why when with a hose it works and when hooked up to boat water it doesn’t
Only thing I could think of is under pressure from hose – it probably forces water in but the pressue is not enough from water pump and exchanger is clogged somehow – however, only one of the ports in the exchanger looked clogged. Stuck wire through to clean a bit but didn't look clogged enough to stop all water from flowing through.
If we force water through the hose to the risers – the water comes out of port on side of hull.
If we force water through the hose to the exchanger and to risers – the water comes out of port on side of hull.
Captain Frustrated -
