itselliott
I had my Crusader 270 Hp 's rebuilt my a Marine specialty shop here in Michigan.
The shop ran the engines in on a wet test stand prior to my taking them.....
After my reinstall, I ran them for 20 minutes at 2000rpm prior to launch......Then,I ran the boat 120 miles at various speeds on the very first run.....never attempting WOT.
After 30 hours of use this summer, I changed the oil and went for a full out run.............the boat fell flat on its rudders..............3700-3900 rpm max.....26 MPH, a huge loss from before the rebuild. 4400-4500 at 32 MPH
Sent the Q jets out for a re do........Cliffs Performance ,....Mount Vernon Oh. The carbs are (IMO) perfect..............but still no WOT.
THEN!!! I did a compression check............130 to 135 on all 16 cylinders!! I think that the shop missed decking the block after a + .020 bore. Or maybe a too fat head gasket?
I no longer have the crane or needed equipment to pull the motors myself and naturally the shop is on the East side of the state and I am on the West Side. Oh, and only a yard style trailer.
I saved the oil filters and a cup of oil from each engine on the first oil change...........visually, I see Nothing in the oil.
How screwed am I?? where do I go from here?? how does a new build come up with such low compression?
