Crack in lower unit housing
stewsbs
I have a very small crack in m
I have a very small crack in my lower unit housing can I seal this using an epoxy or metal mender or even fiberglass I dont want to have to spend $400 on a new lower unit for this small crack
Is it leaking oil? OR is the o
Is it leaking oil? OR is the oil contaminated?
Whatever you decide to repair it with must be able to deal with expansion/contraction from extreme hot and cold. Not to mention pressure up to 12psi. (test pressure for seals).
"Ayuh,...
You need a replac
"Ayuh,...
You need a replacement Housing,.. New or used is your Only choice...
Otherwise,..
Either the Water, or the change in housing dimensions will Destroy the drive..."
How do I know what gear ratio
How do I know what gear ratio I have it's an Alpha One V8 drive on a Mercruiser 233HP
You just need the lower unit;
You just need the lower unit; gears are in the upper half of the OD. Check w/Sterndrives Engineering. You can get a new LU for a good price.
How hard is it to transfer gut
How hard is it to transfer guts from my lower unit to a new housing do I need any special tools is there a gasket set?
"SEI106 lower $600
New case
"SEI106 lower $600
New case $1000, special tools to shim properly,RR old parts,
Do the math"
Are you saying a complete lowe
Are you saying a complete lower unit from them is 600 but a bare case from mercruier is 1000?
complete lower Sierra $1499.00
complete lower Sierra $1499.00 SIE18-2443
bare case Sierra $1125.00 SIE18-2401
from the `07 catalog
