"You are very welcome.... and
"You are very welcome.... and we'll get you through this.
If I may, let's refer to the cam as "indexing" or "cam timing"..... and the ignition as "timing" as to avoid any confusion. Fair enough?
You may have an issue in two areas here, and I welcome input from El P on this.
First, the camshaft must (capitol MUST) be indexed correctly, or you will get no where. So this must be verified before going much further.... or any further for that matter.
Secondly, the ignition timing must reach the correct TA range (total advance).
If your ignition is not advancing correctly for a given RPM, then it may be causing what you are describing..... I.E., falling flat at 2k rpm.
The spark advance must do so as RPM increase!
See your OEM specs for TA or TAT.... total advance timing.
It will give you this in "degrees", and will offer an RPM at which this is to occur.
If the ignition system is not delivering this, then you will not get any performance from this engine..... Simple as that.
It could be as simple as rust within the distributor, or a broken spring, etc.
It is a very critical part of your engine being able to perform well.
Again, first the cam "indexing", then once that is either corrected and/or verified, move on to ignition "timing".
Anything past that may lead you to a fuel delivery problem...... but that is another topic.
