"1989, 200hp Mercury outboard
"1989, 200hp Mercury outboard that does't discharge water from the tale-tale, it starts blowing steam out the tale-tale at idle.I am running the engine on muffs. I replaced the pump impeller, thermostats and flushed engine. The pump housing looked normal with no scarring or pitting. I removed thermostats and backflushed and had water draining near the prop. When I replaced the impleller, I noticed that the water tube is a copper pipe that is about 1-2 ft long, is that normal?Any suggestions would be great."
