"Been restoring a '79 Tiar
"Been restoring a '79 Tiara 2500 with twin 140's which I've been working on one at a time. Today, I got the port side engine running and aside from a few minor adjustments, it runs pretty well. However, I'm unfamiliar with engines such as this one which utilize a closed cooling system. I understand that the engine retains it's own coolant, but then sea water is passed through an exchanger to cool that coolant. Does this mean that I still have an impeller in my lower unit? When I ran the engine, the boat was on the trailer with "earmuffs" on the lower unit. I didn't see any water coming out of the exhaust after several minutes so I shut it down and then tried to submerge the entire lower have of the outdrive in a trash can filled with water. Same thing, no water out the exhaust. I didn't let the engine temp get over 150F. But I know from previous experience that the exhaust can get much hotter than that if it's not cooled properly. Am I doing this right? Am I missing something? Do I need a new impeller in the outdrive? What else could it be? Please help, Thank You."
