"I recently purchased a 1996 4 winns with a 4.3 ltr engine.The owners manual says it has a 4.3 GL, however I suspect that the motor was changed as there is a sticker on a valve cover indicating it is a 432A engine.
My issue, the engine runs cool, so cool that the temp indicator does not register,the manifolds are "lukewarm'. At first I suspected the indicator, however I have since ruled this out.
I suspected that it did not have a thermostat but upon checking I found one, old but tested and opening at approx 160 degrees.
I wonder now if the thermostat is the correct one.
As far as I can determine, the 432A calls for a 876305 unit, the 4.3Gl calls for a 3856961.
Are there any physical differences between the two?
The present set up has a "O" ring as well, I also checked the bypass and it is clear of any debris.
Any suggestions gents?
all appreciated
thanks"
all appreciated
thanks"
