Converting tiller to controls
sticky
"hi all im changing from tille
"hi all im changing from tiller to console controls i need to know what kind of bracket to hold thje steering cable where it wont move,also what kind of throttle,shift cables mount to motor,82 25hp,thanx"
You can buy a fwd control kit
You can buy a fwd control kit which gives you everything for the controls to bolt onto the engine. You then need a side mount controller and cables to suit.
As for the steering cable you will need a transom mount and ball joint conector to attach it to the bracket at the front. (This is presuming you are using a push pull steering cable)
