Capt.C.Delany
Hey guys/gals, long long time lurker, first time poster. I have already gotten so much out of this forum, the wealth of knowledge here is outstanding!
I am in the process of buying the stuff to switch over the old rack and pinion to hydraulic steering for my AQ280 outdrive in my Skipjack. The outdrive is non-power assisted and I have confirmed with Seastar that I need either the HC5328 or the balanced HC5330. Seems easy enough but there is a catch... Space!
The space required will put the end of the cylinder under the fiberglass compartment that extends down under the transom rail. (no idea what it is called? not really a bulwark, but it is the area where most guys mount the trim tab pump) In that position it will be sticking out of the engine compartment.
I am sure that enough people here have done this conversion without those results. I have tried to find pictures of a proper conversion and cannot find anything.
Does the cylinder need to be reversed from the current direction the steering cable goes in? Also, the tube with the threads on the bracket is like 5" with the overall bracket about 11" should this be shorter? Does the threaded piece come apart and the end of the cylinder replaces it?
Also, anyone running an AP44 with either a HC5328 or HC5330? Does it matter if I go with a balanced cylinder or not?
Any help is appreciated it!
