So it seems I have killed a second control module and the boat didnt even get to run on the water. It seems the original one died somehow again between buying the boat and it sitting for a few month and the new replacement has done a similar thing. The last time I started the engine, second turn of the key after it kicked with the choke on and idled so smooth and ran perfect. When I went to just give it a run after sitting for a month and replacing the fuel tanks and fuel lines its screwed again. The only thing is the battery every now and then has been put on a trickle charge.
Any help here would be appreciated as this is a really expensive repair over herein Australia. Last time i replaced the trigger module for a sierra brand along with a genuine voltage regulator.
Regards
Leachy
Regards
Leachy
