I tested the compression for my Mercury 8HP four stroke with the guy from whom I bought it and it gave us a reading of 120PSI on both cylinders.
When I looked it up later it showed 120 is quite low for a Mercury but I remembered the throttle was in the idle position.
Would W.O.T. give me a different (higher) reading? If so, can I assume that 120PSI with throttle 'closed' is sufficient enough?
The motor in question: Mercury 8HP four stroke - 2006
Thanks in advance!
Thanks in advance!
