Those are very low readings UNLESS the engine is cranking over rather slowly.
Does your warning horn beep momentarily when you turn the key to the ON position? If not, test the horn as follows:
Engine NOT running. Key in the ON position. Ground the TAN wire that you see protruding from the cylinder head. The horn should sound steady. Does it?
Does the tell tale hose come off the side of the block or off the top ?-------------My gauge would show 120 psi on one of those motors.-----------Has oil injection system been maintained / checked ?
The normal diameter of the black throttle roller is about 3/8" and it was a one piece item. A number of years ago, someone decides that it should be a two piece item... a smaller black roller (approximately 1/8" in diameter) , covered by a larger clear covering to bring the diameter up to the normal 3/8".
Problem is that eventually that clear roller breaks away, leaving a 1/8" diameter roller that throws everything out of synchronization..... Check the roller.
Sounds like the pack is going into slow,,,disconnect the tan or brn wire(depends on mfg) from pack and retest
Sounds like SLOW mode to me too.
Check for overheat. Disconnect tan wire from temp sensor on head.
Be sure it IS NOT overheating before running with the tan wire disconnected.
What are the RPMs when it shakes? 20 mph doesn't say much.....
No removing the head until you determine if it is or is not overheating.
Use a digital laser thermometer, or hold your hand on the head for a count of 4-6 til you HAVE to pull it away.
It should run 140F or so.
If it is NOT overheating, pull the tan wire and see if the violent shaking goes away. If it does, use an ohmmeter on the temp sensor side of the tan wire, and see if you have continuity to ground. If the temp is 142 for example, and you have continuity to ground, then the temp switch in the head is bad.
Much easier than pulling the head at this point. Much easier and no parts costs unless you find a defective temp switch/sender.
Uh oh.
Now things are getting tough.
So, I guess the question is....is it really in SLOW mode? All I can go on is your description of shaking violently.
Can you add to this in any way to help me understand exactly what "shaking violently" means?
Well, I will describe SLOW mode....see if this matches...
The engine hits 2500 rpm or thereabouts, and very rapidly begins fast up and down of the RPMs. Rev up, down, rev up, down, rev up, down....very fast succession.
This causes a shaking of the whole motor.
If you are hitting a 20 mph limit, could it possibly be a spun prop? Mark using a magic marker across the prop hub, thru the center of the prop nut, and on to the other side.
Run it, and see if the mark has moved after the shaking begins.
If this is not it, I am at a loss at this point. I really do not believe that low compression would cause violent shaking, just a loss of power...not shaking.
Even if you lose one cylinder, the engine will not shake violently.
If you can post a video, that would help.
You say it has a new pack on it. Is there any possibility that you have pinched the tan wire going into the pack between a mounting boss or any other metal part of the block?
That would make the pack think it was in overheat, and trigger SLOW mode.
I told you in post 24. Mark it with a magic marker. see if line has moved after a run.
