s2sailorlis
Getting started on a first-time total rebuild project - 1986 Colt 1.2hp. Factory service manual is on order...
At this stage, main task is to clean engine block and gasket surfaces. Please see attached. I am thinking of using carb cleaner and scotchbrite/plastic scraper for gasket surface. And carb cleaner for exterior. My concern is getting carb cleaner into the cylinder area - would this be an issue? Guess I could stuff some rags into the cylinder area. (carb walls look good - cross-hatching still visible - piston looks good with no blow-by past the rings. Also, can I re-use the rings (not sure they make them any more...)
Note that this engine is for ocassional use on a 9 foot dinghy when I am lazy and not wanting to row..
