My 1990 90hp Evinrude will not start cold. Starts on first try if I spray gas into one spark plug hole or use starter fluid in air intake. after running even seconds, it restarts immediately and runs well. will restart even after several hours of sitting. To cold start i pump bulb to hard, advance throttle in neutral to a high speed, push in key and it cranks but no sputter even. One shot of starter fluid and it roars. I checked voltage to the solenoid (11.8 v); disconnecting primer solenoid to upper carb it does squirt gas when key is depressed. I want to start without the drama and i know starter fluid is a bad option. I owned engine for 10+ years and it has been reliable. Any ideas?
