Engine starts with one or two pulls, normally. Unless it has been sitting for for more than 4 or 5 days. Then can take 5 to 7 pulls to start. Once started it will start on 1 or 2 pulls every time. Compression 75 on both cylinders. Good sparks. Engine runs well at all speeds and idle.
My thinking is that the gas fumes in the crankcase and combustion chambers dissipate in a couple of days and it takes more pulls to drawn enough fresh gas fumes through the system to the firing chambers. Compression is not high so it takes more pulls to charge the system with fumes. Once the system is recharged with fumes it is ready to fire with one pull.
Is this normal operation for this old engine?
Or should I consider new rings and/or reed valves?
