Chyrsler outboard
kevin
I have a chysler 105 hp 1978
I have a chysler 105 hp 1978 and has only done 350 hrs problem is the crankcase is cracked next to the water jacket which apparently is common can this be repaired as it would be a shame to throw it away
"Kevin..... It depends on exac
"Kevin..... It depends on exactly where the crankcase is cracked, a judgement call you'll need to make. Marine Tex in the "gray" color (not white) will repair a crack quite nicely, and that area will be stronger than the original casting.
Joe
I HAVE RECENTLY INHERITED A C
I HAVE RECENTLY INHERITED A CHRYSLER 50 HP MODEL NUMBER 507S4A CAN YOU PLEASE TELL ME WHAT YEAR IT IS.
"Richard,
I don't see t
"Richard,
I don't see that exact model number in the index that I have for Chrysler outboards... but I would guess it is 1982 or 83.
Regards,
Andrew"
I would like info on the char
I would like info on the charging system for my
1980-1 85 hp chyrsler outboard circut diagram and avalibility of spares
Regards
Kevin F Cox
South Africa
I would Like to know where I
I would Like to know where I can buy a regulator for a 1980-1 85 HP chyrsler outboard can any one help.
Regards
Kevin F Cox
" if I repaired completely the
" if I repaired completely the motor, change them 3 pistoneses, as I must use the motor initially in order that he fit up and as he is the gasoline and oil mixture that I must use.
my motor is a force 85 hp 1985 "
I would like to know the gas/
I would like to know the gas/oil mixture for a 1975 Chrysler 20 hp outboard.
