rumdrunksailor
SO here's the issue, my starboard engine is stalling out. It will run fine for about an hour and then die. I have to let it cool before firing it up (maybe 10 minutes) and then it is hard to start. I have a new 1409 carb on there (stalled out with old AFB too), also new exhaust elbows. Engine seems to run at normal temperature at cruising speed but can boil over at higher rpms. I suspected vapor lock (still do) so I tried wrapping the old copper fuel line with rubber hose (at least the part from the fuel pump to the carb). I have also replaced the fuel filter. It should be noted that I only have one gas tank and the port engine doesn't die so I do not think it is the gas.
I have also switched it over to electronic ignition (pertronix).
The engine will start to stutter and lose power and then die. Also, if I back off the throttle even when it's running well it will start to stutter and die. Like I said after 10 minutes I can put the throttle in WOT position and get her to fire up after about 15 seconds.
Also, I checked timing after doing the sticky distributor maneuver I read about here. I have it timed at 5 degrees initial, but it is only at about 16 degrees at 3k rpm. I did not replace the coil when I put pertronix on but I did bypass the ballast resistor.
Thoughts?
Thoughts?
