View attachment raw water cooled manifold set up.pdfView attachment osco-pg22-25.pdf
Just wanted some opinions on if my raw water cooled set up is correct, the tech document from osco does not have a picture and the instructions are not too clear, I just want to be certain my set up is right. If I understand it correctly the purpose of the distribution tube is to remove trapped air from the manifold, and this tube is only used on raw water cooled applications. I know trapped air will make its way to the highest point in the manifold, so the tube would then be inserted from the rear (transmission side). I drew a picture of how I think the set up should be just wanted to double check myself. The one attachment is my hand drawing, the other is the tech document from osco.
KMD
KMD
