I checked my engine compression after I have been having trouble getting the my engine to start. Engine is an AQ131D. The compression checked accross all 4 cylinders was 130 on all four consistently. I checked by removing all plugs and the ignition coil wire ensured the timing marks lined up and the turned the engine over through several revolutions. the readings stayed the same throughout. My question is should the compression hold at the point where I stop the engine? Meaning if I just tap the key and the compression goes up to 130 and I stop, should it remain at 130? It isn't on mine, just drops back to 0 when I stop turning the key. Just want to know if this is normal. Thanks.
