joe_merchant
Currently, my AQ280 prop rotates counterclockwise (left hand prop). Since it's 35+ years old, was wondering if switching over to right hand rotation would affect the set of the clutch or gears in any way?
In a nutshell: no, it won't. Or I whould rather say: "It should not".
Good answer - ever consider a career in politics?
I was pretty sure it shouldn't affect anything but wanted to ask. My transducer is on the right side of the prop and was told that the back side of the prop can cause "ghost fish" readings. Going to a four blade prop and thought I'd try to kill two birds with one stone.
- Now in the RH direction in forward gear the top gear is the drive gear and the only thing holding all that force down is the top housing cap and those four allen bolts.
- Yes the bottom brass split ring keeper can be a real ugly part when the steel keepers pull thru, makes for a really cool 2" diameter hole in the top cap and pretty colors in the water.
- Oh and Rick, I've been putting a steel/brass split ring keeper in place of the all brass one for 30 years on the higher horsepower engines,
