I'd first verify the over-all gear ratio by removing the prop shaft ring anode and revealing the numbers that will be stamped into the bearing carrier.
If it is the 1.95:1 DP lower, then yes, it will work on your 28 footer with the correct prop set.
Probably a B2.... maybe a B3 set.
(all uppers in this series are of same ratio)
NOTE: Critical shimming adjustment must be done to the vertical shaft bearing race when swapping lower units.
The original race from the DP will need to be carried over to the Intermediate housing of the 28 footer (and visa-versa).
Shim this according to OEM procedure..... it is shown in the OEM service manual!
BTW, this is a negative pre-load!
The Duo Prop drive oil now changes to GL 5, and the smaller boat (with the single prop drive) now goes back to engine oil!
Easiest is to change the lower unit only..... but not at the cost of forgoing upper unit maintenance.... i.e., new Bellows, U-joint bearing crosses, main drive seal, etc.
It takes me almost as much time to properly R & R the drive oil as it does to calculate the shimming.
The install is easy.
To swap both lower units, you will need a total of eleven (11) new O-rings; 2 for pivot tube, 2 for center bearing, 2 for oil drain back tube, 1 hollow bolt O-ring and 2 dip sticks and 2 drain plugs!
Don't forget the one 280 fill plug gasket (270 does not have typical fill plug).
I'm the PDSB (primary drive shaft bearing) NAZI, so if you have not yet replaced these, I'd strongly encourage you to do so!
That DP will make your 28 footer happy!
Have fun!
