"Hi there!
The cav-plate wo
"Hi there!
The cav-plate would not be there if it was not deemed neccessary... Manufacturers want to save cash...
You'll notice that the boat will not plane properly and also have some prop-slip (read: cavitation) when throttling up. The anti-cav plate prevents air from being sucked into the prop's wash. If this makes sense? Think along the lines of the motor being trimmed too high and motor starts to over-rev. Same principle, not enough water thru the prop's blades. Also, the prop will wear out prematurely due to the excessive strain.
So, you'll end up wasting fuel, not having a pleasant day out and ultimately considering selling the boat because of poor performance.
Hence, have it repaired ASAP!
Regards from a cold, wet and wintery Johannesburg in South Africa!
Benjamin."
