Hello, I'm having trouble with my 2005 15hp 4 stroke merc outboard. It runs great, but fuel leaks between the accelerator housing and the accelerator pump housing cover (at bottom of carburetor). I cleaned the unit and installed a carb kit. Motor still runs great, but when I twist the throttle, it pumps fuel out at the aforementioned area. There was no gasket at this mating surface...just a couple of O-rings(flat rings, really), and the accelerator pump diaghram. Can anyone advise? I need to get this motor fixed ASAP as I'm transferring ownership. I'd rather not buy another carburetor, but will if necessary. Would replacing the diaphragm do it? The O-rings/flat rings, aren't listed in the marine.com parts breakdown, so I don't know if these are even available. Any thoughts greatly appreciated.
David Tye
David Tye
