Carb Rebuild
f300k
When I took the carb off my AQ
When I took the carb off my AQ125a I found a restricter plate. Can anyone tell me whats up with it and could anything be gained buy not putting it back on
Give it a try. Sounds like the
Give it a try. Sounds like the cost to do so would be a couple of Banjo washers and a gasket or two.
"I guess it 20A a flange. It i
"I guess it 20A a flange. It is the thickness of a gasket and sets between 2 gaskets. looks like this
The openings in the carb and the intake are round, so this cuts off a small amount of air, gas mix from entering"
"It appears to me that the pla
"It appears to me that the plate has that shape to add turbulence to the air/fuel mixture (or perhaps to stop drops of fuel to reach the manifold), but I could be wrong. I don't think you should remove it and I further don't think it is restricting the air/fuel intake. The narrowest cross section in the carb (which is in way of the butterfly throttle valve or by the Venturi) is what determines the maximum air flow."
