Ok so here's what I got. 1973 Merc 200, 20hp with a type B carb. Motor Serial is 3671256. I took down the carburetor and soaked all metal parts, replaced all gaskets on the carburetor and fuel pump. Put it all back on. Set the idle screw 1 1/4 out of seat. Primed up the bulb. Now here is where it gets funky. I pull out choke button and attempt to pull. After the first pull fuel starts leaking out of the carb. If I shut off the choke, no leak. Now after 1 pull with choke, she tries to fire. 1 pull with no choke she fires but only for a second. Multiple attempts and choke adjustments yesterday I had her running for a minute or 2 but I had to keep choking on & off. I know I'm missing something. Another note, when I reassembled the carburetor I blew in the fuel pump a little with the carb right side up and air went through, upside down air did not. Or vice versa. Heck I cant remember. I just remember reading on here to test it that way to make sure the float needle was seating. So what are your guys though?? Do I need to tear her back down???
