"Hi all, I was doing me routi
"Hi all, I was doing me routine tune up on my 1989 4.3L/Alpha package and noticed that the plugs were black and gas covered. Now granted I had just run the engine at idle to warm up the engine oil a bit for a change... She has been running OK, but with a very noticable gasping hesitation off idle. This is an Edelbrock 1409 Marine carb (Weber). Eddy tech said could be too much fuel and to verify the electric fuel pump is not exceeding 7 psi and check the float level. Pump is a Mr Gasket 12S rated for 4 to 7 PSI. I am putting a guage to it this weekend. There is a noticeable odor of gas, not super strong mind you, but there. in the doghouse.
This was a brand new carb last season, and is running the smaller metering rods and jets for the 4.3L. (Edelbrock kit 1495) Oddly enough, I do spy a bit of gas around the secondaries where the weights are.. only on the fuel inlet side though. I'm going inside it to check this weekend. I know we have carb guys here who have torn into their share... thanks for any help in advance.
FYI timing is on spec at idle of 650-700 or so?"
