Guys,
I've been working on my 50 HP '87 Evinrude for the last couple of days. I've replaced the VRO for a normal fuel pump.
Engine (still) bogs and dies on throttle so disassembled the carb and found the problem to be in the high speed jet being broken and closed; no fuel running through. (which is not uncommon for this issue)
The problem I now have is that one jet is broken and are stuck in the float chamber.
Any tips how to remove them without needing to replace the float chamber?
Original jets are 50,- each. Would there be a cheaper replacement part or solution?
Top Carb:
Lower Carb
Top Carb:
Lower Carb
