1994 J48ESLERD will not raise up. I understand these motors have a cable actuated gas charge cylinder designed to assist in lifting the motor but I can not get the motor to move more than a few inches when I pull the Tilt Assist Lever rearward. I imagine the cable is broken but I don't see a cable anywhere. Do I need to pull the engine off the boat to work on it?
I've read the gas charged cylinders are notoriously unreliable and expensive. Is there a work around like simply removing the cylinder if you don't care about the assist function or will the motor not lock down if I remove it? I'd be satisfied if I could just raise or lower the motor manually.
