Cannot turn left or right,
zhome888
I have an older Seaking motor PN: 7wb27903a SN: 76x14066 I cannot move the motor left or right. It seems like it is sized up. Where can I find a manual to rebuild the motor or what can I try to turn it?
The older models, some had a screw to tighten or loosen the mid section.
Undoing the screw sometimes helped.
Other times no!!
Other times a propane torch use along the grease passage,
Heat add grease and heat and add grease.
Apply pressure back and forth as you add grease and heat.
Other times no!!
Thanks I'll give it a try
