Can somebody look at it
sashko12
"Does the tip look too short &
"Does the tip look too short (used up) and the whole rotor needs replacement? Or should this still be ok?
On 1970 Johnson 60 HP 3Cyl.
tip1"">
tip2
"I don't recall the exact
"I don't recall the exact length of that rotor tip, nor do I have any left in stock to compare it to. Hopefully some other member will drop in with the proper advice."
"the tip,does not look good,..
"the tip,does not look good,...if new is still avail,i'd repl it for sure...if not,clean it,and file square it up.i would also,repl the cap!.if new avail..and wires."
