I have a 79 Evinrude outboard. It has been in cave storage for 7 years, dry and covered. Supposedly worked last time my sister had the boat out.
I have 12.46 volts at the battery, at the positive side of the solenoid, and at the ignition switch. I have jumped the positive to the starter and get it to raise and turn. I have jumped direct from the battery to the yellow terminal on the solenoid and the starter turns. I did replace the ignition switch due to lost key(but have verified correct wiring pattern). When I turn the key I get the primer pump noise, but no solenoid activation, no starter, nothing. I have verified that the neutral cutout is working correctly inside the remote control by manually holding it down and the primer pump activates when depressed.
I really feel that somewhere the yellow wire going to the solenoid is grounded out or broken, but I cannot find where.
Is it possible to run a wire direct from the battery to the yellow terminal on the solenoid with a toggle switch or momentary switch in it to bypass the yellow wire coming from the ignition switch all the way back to the engine?
If so, how would you suggest that I do that?
Thanks in advance for the assistance.
-Brian
-Brian
