Buzzer
Jerryjerry05
Outstanding Contributor
I have an 02 90hp Yam
90TLRA
6HI L 509357
The alarm starts as soon as the key's turned on.
I have unhooked the temp sensor so it doesn't get a signal from that.
The motor is cool, hasn't been started.
The oil tank is clean no crud. It is 2/3 full.
The alarm shuts down if I move the float up to about half way.
But if it goes all the way to the top the alarm sounds.
I figure the alarm sender(level gauge assy.) is bad?????
Any thing I should test or look for?
The tach doesn't have any lights or any indicators just the buzzer.
Thanks,Jerry
I got a manual from the owner and did some tests on the sending unit.
Turns out according to the tests the sender is bad.
Ordered a new one and it's on the way.
