"Hi, can anyone help - please!
"Hi, can anyone help - please! I am working in Liberia (west Africa) and last year bought a BRP 115 model PLSDA which I believe is a 2006. It was working fine and now it has developed a problem. Occasionally the oil warning light comes on but I believe it is consuming oil as the level is dropping. It is running fine in a drum off the water and in the first 5-10 minutes in the water and then suddenly it starts to shake and it will not go above 2000 revs or so and has to be nursed back to the jetty. Is this the S.L.O.W mode kicking in? How can I tell whether it is this S.L.O.W mode? If it is, how do I proceed from here? What simple checks can I do? We have already cleaned the carbs, changed plugs and initially it works fine and as I said, then suddenly it vibrates and slows to max a few knots at a few thousand revs. Can anyone help???!! Unfortunately here in Liberia there are no good outboard mechanics! Thanks"
