dodgetkboy78
"Last week, out of the blue, t
"Last week, out of the blue, the crankshaft broke, at the #8 rod journal, on my M360. Nothing out of the normal, 2600rpm, 1/3 throttle, just happened. Anyone seen this one before? The 360 replaced a 318, and I am not sure if they replaced the 318 flywheel with the external balanced 360 one, I have seen it done in a car, and it didn't vibrate that bad......
Anyway.
IF I just cant put a new crank in the 360, what would it take to marinize a 318. Mostly, this motor is RH. How do they deal with the oil pump, ect? Is there a gear set up to spin the cam the same way?
I have been building, working, driving, and modding SB chryslers since before I had my drivers lic, but the opposite spinning motor is new to me.
Also, if I do go the 318 route, the 360 pan wont work. What is the reason for the cast pan? Could I use a rear sump truck pan? (steel) Are they cast aluminum for rust issues? Or something else."
Anyway.
