My outdrive reservoir tank on my Bravo 2x is leaking below the tank down into my bilge about 1/2 tank a day even when the boat is sitting. I’ve placed paper towels all around the oil tank and lines and found nothing. The only conclusion I can come to is it’s leaking at the thru hull connection or hose right above it. I can’t even see or reach that part because it’s so tight to the motor. I’m looking for some advice on changing the thru hull fitting and hose or recommendations if there’s something else I should consider as the source of the leak. I did change the outdrive oil and it looked good. So I’m pretty sure it’s between the reservoir and thru hull fitting. I’ve attached a pic of a new fitting I purchased (brass instead of plastic) Thank you for any advice you can offer.
